1996 Saturn L200 my saturn problems
190,000 MILES • 4 CYL • 2WD • AUTOMATIC
SUSAN HENSHAW
why does my car jerk as if it is going to stop. This happens intermittently, when I'm driving or at trafic lights. I was told it is the sensor. I fixed that and then was told oh it has two sensors you need to fix the other one too. I think I'm getting the run around.
May 25, 2010 at 6:20 PM
  • 31,937 POSTS
Hi there,
What set fault codes were you fixing, do you have the code Nos. this will be a big help, also check for any engine vacuum leaks as well.
mark mhpautos)
May 26, 2010 at 12:08 AM
