1993 Saturn L200 Breakes going to the floor
1993 SATURN L200
FRED ASCHE
Brakes problem
1993 Saturn L200 4 cyl Front Wheel Drive Automatic
Hi, I have check the vacuum booster It's O.K. I have blead the breakes Also put new pads and shoes on I am lost now at what to do. The peddle goes to the floor.
Thanks
Jun 11, 2008 at 12:04 PM
  • 31,937 POSTS
Hi there,
You may have a faulty master cylinder that is by-passing fluid internally. This will case the pedal to drop and there is no fluid loss. You can normally pick this by pumping up the pedal and holding hard pressure , the pedal will normally sty up but if you back off the pressure and hold constant light pressure the pedal slowly drops away.
Mark (mhpautos)
Jun 11, 2008 at 12:08 PM
