Saturn L200
KC2124
Series of events….
Saturn L200 Series
Car runs fine
Start Driving, fans / blower turns on high
Car start shifting really rough in lower gears, runs fine when going high speeds
Dealership says replace motor mount….I say B.S. they haven’t done a scan or anything.
Would the motor mount be the real problem here? Seems to me it would have something to do with the fans coming on as that is when the problem of hard shifting starts.
Another note. When you turn the car off and let sit, the problem goes away until these fans / blowers come on.
ANY HELP WILL BE GREATLY APPRECIATED.
May 20, 2013 at 12:05 AM
SATURNTECH9
  • 30,869 POSTS
The radiator fans come on high like that usually when there is a really bad miss fire.I would have it scanned for codes first.Let me know the exact code numbers not code descriptions? The most common reason for them to shift hard is a bad pressure control solenoid in the valve body.
May 20, 2013 at 12:41 AM
KC2124
I had them do the engine scan and it came back with the TPS being bad. It's half the cost of the motor mount so I am pleased with that.
Love this forum. THANK YOU!!
May 20, 2013 at 1:23 AM
SATURNTECH9
  • 30,869 POSTS
A tps issue will cause hard shifts let me know how it comes out?Also what is the exact code number you have?
May 20, 2013 at 5:28 AM
KC2124
I didn't get the exact code yet but I will and would love for you to check it out for me.
THANK YOU again!
May 20, 2013 at 5:57 AM
SATURNTECH9
  • 30,869 POSTS
Not A problem get me that code.
May 20, 2013 at 11:27 AM
KC2124
o.k. so the car repair shop says they won't give out the codes. I know Auto Zone in our area does a free scan....will this be the same scan? Not sure what the repair shops problem is. The car is running fine now that the TPS was replaced but we haven't been able to drive it for an extended period of time.
May 20, 2013 at 10:53 PM
SATURNTECH9
  • 30,869 POSTS
For the tps code yes auto zone maybe can get you the. Code. If there scanner can read history codes.The deal with the shop is they spend thousands of dollars for scan tools.Plus the software updates for them aren't cheap.So to give out codes I don't blame them for not doing that.
May 21, 2013 at 12:07 AM
