2002 Saturn L100 oil leak in engine
97,000 MILES • 4 CYL • 2WD • AUTOMATIC
SPITTIN
what kind of repairs would I need if oil is leaking under the engine and the seal in the back of the engine?
Jun 29, 2010 at 9:04 AM
SATURNTECH9
  • 30,869 POSTS
So are you saying the rear main is leaking?The seal around the crank shaft where the transmission bolts up?
Jun 29, 2010 at 9:13 AM
SPITTIN
yes
Jun 29, 2010 at 10:30 AM
SATURNTECH9
  • 30,869 POSTS
8.2hrs labor time's shop labor rate.Plus alignment and the seal and transmission fluid etc.
Jun 29, 2010 at 5:43 PM
