what kind of repairs would I need if oil is leaking under the engine and the seal in the back of the engine?
Jun 29, 2010 at 9:04 AM
SATURNTECH9
✓ASE Certified Mechanic
So are you saying the rear main is leaking?The seal around the crank shaft where the transmission bolts up?
Jun 29, 2010 at 9:13 AM
SPITTIN
MEMBER
yes
Jun 29, 2010 at 10:30 AM
SATURNTECH9
8.2hrs labor time's shop labor rate.Plus alignment and the seal and transmission fluid etc.
Jun 29, 2010 at 5:43 PM
