Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Saturn
L100
Engine
Symptoms
Misfire
2002 Saturn L100 MISFIRE
2002 SATURN L100
46,000 MILES • 4 CYL • FWD • AUTOMATIC
DEREK1972
MEMBER
1 POST
CAR HAS RANDOM MULTI MISFIRE CODE CHANGED PLUGS,MODULE,COIL PACK STILL HAS SAME PROBLEM
Mar 27, 2009 at 7:39 AM
KHLOW2008
Experienced Mechanic
Hi DEREK1972,
Thank you for the donation.
Apart from spark plugs and ignition faults, low fuel pressure would cause multiple misfiring.
Check the fuel filter and fuel lines for possible restrictions.
Mar 28, 2009 at 9:18 PM
Add image or video
Ask a new question
Engine won't start
Engine has low power
