2002 Saturn L100 Fuel pump
JW7684
  • 10 POSTS
2002 Saturn L100 4 cyl Front Wheel Drive Automatic
I was wondering if you know where to locate the fuel pump on this car.
Jul 8, 2010 at 5:07 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the fuel pump is in the fuel tank
Jul 8, 2010 at 5:58 AM
JW7684
  • 10 POSTS
So is there an easy way to get to the fuel pump other than dropping the tank
Jul 8, 2010 at 6:21 AM
BLUELIGHTNIN6
  • 16,542 POSTS
there is no access panel to the pump assembly, you must drain and remove the fuel tank from vehicle to replace the fuel pump module.
Jul 8, 2010 at 6:23 AM
JW7684
  • 10 POSTS
ok thanks for your help
Jul 8, 2010 at 6:24 AM
