2002 Saturn L100 coolant leaking
125,000 MILES • 4 CYL • FWD • AUTOMATIC
SPEAK1104
Our car is leaking coolant, but we cant tell where from. It started leaking only periodically, but now the coolant pretty much runs straight through. We cant afford to put it in the shop. Where should we start?
Oct 7, 2010 at 2:55 AM
SATURNTECH9
  • 30,869 POSTS
Your going to have to rent a coolant pressure tester and pressurize the cooling system and follow the coolant leaking.On those car's the most common place's i have seen leak is the water pump and heater core's.
Oct 7, 2010 at 5:50 AM
