2002 Saturn L100 Blower motor doesn't work
2002 SATURN L100
MOPOWRMIKE
Heater problem
2002 Saturn L100 4 cyl Two Wheel Drive Automatic
I have replaced the blower motor on my brothers car as well as the fan switch and the motor still does not blow. Any suggestions?
Jul 30, 2009 at 12:05 PM
MERLIN2021
  • 17,250 POSTS
Will not blow on ANY setting? High? Pull the plug on the blower, and check for power at the Orange wire if memeory serves me right! Check black ground wire, then the only two things you havnt done, and it can be either...Blower motor resistor, mounted between switch anf blower, and on the blower plenum, then the ignition switch has been known to cause it as well. Resistor is USUally the problem. To get specific info for you I need to know if it's manual or auto temp?
Jul 30, 2009 at 12:12 PM
