I have a Saturn L100 Series. Everyday I have to add transmission fluid to car, because it beginnings to slip. It works fine after I add the fluid. I usually have to add 1 1/2 quart. This problems occured at the begining once every two-three weeks. Now it is occuring every so many days. The problem is, there is no indication of a leak. We put paper under the car, for long periods of time to check if there is a leak. This car doesn't have a transmission dip stick, so we don't know if or why it is getting low so often. The paper is dry, indicating it isn't leaking out of the car. Is the transmission going out, is the fluid leaking into another location in the engine, or are the seals going bad. Please help.
SPONSORED LINKS
Tuesday, April 6th, 2010 AT 6:28 PM
