2006 Saturn Ion Power Steering goes out
39,950 MILES • 4 CYL • 2WD • AUTOMATIC
VISARRARAZ
My power steering goes out as I'm driving at times. All I have to do is turn the car off and turn it on again and everything is ok again until about 20 to 30 more minutes of driving again, then it goes out again and becomes hard to steer. I have seen on this site that one other person has experienced the same thing. What is the problem and what is the best way to fix it?
Dec 21, 2008 at 5:15 PM
DOCFIXIT
  • 18,828 POSTS
Hi
The only part that could work one time and not another and particularly turning off and on to get it to work is the steering control modual. Located on collum a box with wire term. Needs to hooked up to a scanner to see what codes are set that may verify fault.
Thanks for donation
Let me know if codes are present will advise
Still under warranty for steering?
Dec 22, 2008 at 1:59 AM
