A/C blows warm air
CTHELENA
A/C blows warm air but Freon is full. what could the problem be?
Nov 8, 2009 at 2:29 PM
  • 75,988 POSTS
This can be because of a blown fuse or a blend door actuator is not working right here is a guide to help you check the fuses.
Here is a guide to help you with the blend door actuator.
Check out the diagrams (Below). Please run this test and get back to us.
Cheers
Nov 9, 2009 at 2:13 AM
CRISIS169
I had my 2004 Saturn Ion 1 for almost fourteen years now around 2010 the AC started to roar loudly at one time had hot air coming out I want to a Jiffy Lube and they changed out my air filter for my car and the outside air works fine. I tried the AC today it came on and cool really fast but it still makes that loud roaring noise. Is my AC going out or just needs to be cleaned. What do you recommend I should do? I know if I take it to a shop GM specially it will be over $1,200.00 at least to get a new AC compressor put in.
May 13, 2018 at 3:46 AM
  • 55,579 POSTS
You can do the job yourself by following these guides.
https://www.2carpros.com/articles/replace-air-conditioner-compressor
and
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
The compressor should run about $250.00 on Amazon.
Cheers, Ken
May 13, 2018 at 4:35 AM
ANONYMOUS
  • 0 POST
I had this problem with y car it ended up being the mode cam was all jacked up here is what the part looks like below. FYI
Aug 5, 2018 at 1:58 PM
