2006 Saturn Ion AC not working.
30,000 MILES • 4 CYL • FWD • AUTOMATIC
GUERRER5
Last summer my AC worked fine, i decided that i wanted to add refrigerant to it to make it cooler since it was too hot in my hometown. My brother in law put the whole bottle of refrigerant in to it when i turned the car on the air started to come out HOT! it doesn't come out hot anylonge, it comes out warm.
I had a mechanic look at it today and he said that is either the compressor or that it needs refrigerant, is this true??
Thank you very much!
Jun 10, 2010 at 4:32 PM
  • 55,694 POSTS
Hey Guerrer5
Check the high and low pressure with a manifold gauge to determine the amount of freon in it, if okay also check if the magnetic clutch is engaging the compressor when you turn on the AC.
Here is a guide that can help you get the problem fixed.
Please let us know what you find so it will help others.
Best, Ken
Dec 4, 2016 at 12:27 PM
