2006 Saturn Ion
55,000 MILES • 4 CYL • 2WD • MANUAL
KRISTENAPPLIN
I have had my car about a year and a half now and have only had problems with it during the winter. When it gets down below 45 outside my car wont start or even turn over whatsoever. My battery has already been tested and is good but I was told it could have something to do with the relay. I had this same problem last winter and took it to the dealership and all they could tell me was there was nothing wrong with it. Any ideas?
Nov 25, 2009 at 6:23 AM
SATURNTECH9
  • 30,869 POSTS
sounds like u have a bad ignition switch theres a bulletine about no starts below like 40 something the dealer should have known that they have redesigned that switch like 3 or 4 times i have replaced lots of them for that same reason.if u have them check for codes in the body control module u probably have a code b2960 and a b3033.there not that hard to change ethier hope this helps have them check for those codes but best bet is that ignition switch.let me know how it goes.
donations and feedback greatly appreachiated
louie
Nov 25, 2009 at 7:32 AM
