2005 Saturn Ion Trouble code PO506
MUSTSAW
Engine Performance problem
2005 Saturn Ion 4 cyl Two Wheel Drive Automatic
Looking for possible solutions to this code PO506
Jun 9, 2010 at 12:18 AM
  • 75,988 POSTS
P0506 code is one that's sometimes triggered on vehicles that have electronic throttle control. That is, they don't have a regular throttle cable from the accelerator pedal to the engine. They rely on sensors and electronics to control the throttle. In this case, the P0506 DTC (diagnostic trouble code) is triggered when the PCM (powertrain control module) detects an engine idle speed that is lower than the desired (pre-programmed) RPM.
OBD-Codes.com on FacebookPotential SymptomsMost likely the only thing you'll notice is the idle speed is lower than normal so it will likely be rougher. There are potentially other symptoms as well. Of course, when trouble codes are set, the MIL (malfunction indicator lamp, a.k.a. the check engine light) illuminates.
CausesA P0506 DTC trouble code may be caused by one or more of the following:
A vacuum leak
An air restriction in the intake air path or exhuast
A faulty positive crankcase ventilation (PCV) valve
Damaged/failed/dirty throttle body
Internal engine problem
Failed PCM
Possible SolutionsThis DTC is more of an informational code, so if there are any other codes set, diagnose them first. If there are no other codes, inspect for vacuum leaks, restrictions, and damage. If there are no symptoms other than the DTC itself, just clear the code and see whether it returns
Jun 9, 2010 at 12:24 AM
  • 31,937 POSTS
Hi there,
Check general tune items and idle control system, this shows up as a low idle problem.
mark (mhpautos)
Jun 9, 2010 at 12:28 AM
