2005 Saturn Ion Power steering
112,000 MILES • 4 CYL • 2WD • MANUAL
SUPERBUYR1
  • 6 POSTS
I was driving home today, and had made several stops. but the last time I stopped, when I started again, I didn't have any power steering and then the power steering light came on. I turned it off/on and the light still came on. I drove it the 3 blocks to home and turned it off. Later I went to pull it into the garage and it seemed to work fine.
(I just remembered, that I had a Power Steering light flash at me a while back, but it went out).
My first thought was to check the fluid, but now my question is, does the car have power steering fluid? There is NOTHING in the manual about it at all.
Any advice from anybody. I'm obviously worried about driving it.
Jul 24, 2010 at 12:49 PM
SATURNTECH9
  • 30,869 POSTS
You have a electric motor on your steering column so no fluid.What's probably failing is that motor pretty common for those car's.You would have to see what code's you have in your power steering control module.
Jul 24, 2010 at 1:10 PM
SUPERBUYR1
  • 6 POSTS
Thanks for the info. Is the car safe to drive to have it checked out?
Jul 24, 2010 at 1:27 PM
SATURNTECH9
  • 30,869 POSTS
I would get it checked when the power steering goes out it make's it pretty hard to steer.When they start doing that they only get worse.
Jul 24, 2010 at 1:31 PM
