2005 Saturn Ion Engine will start then die in about 4 secon
114,000 MILES • 4 CYL • FWD • AUTOMATIC
ROVERBOY74
I have checked codes and there are no codes present. I checked fuel pressure and it is 55 PSI The check engine light was on but I cleared it and it has not come back on. The passlock light was on and I reset it. The car will start and run for about 4 seconds then die. It runs smooth then begins to run rough and dies.
Oct 19, 2010 at 3:10 PM
  • 75,988 POSTS
Hi Roverboy74, Welcome to 2carpros and TY for the donation
When it dies after that 4 secs, does it start back up with no problem or you have to wait-let me know
Oct 19, 2010 at 3:44 PM
ROVERBOY74
The car will start right up with no waiting period and will run fine for 3 of the 4 seconds then runs rough and dies.
Oct 20, 2010 at 3:11 AM
  • 75,988 POSTS
Hook up a fuel pressure tester and monitor the pressure before it dies, if okay-test the powertrain relay and the run/crank relay in the underhood fuse block
Oct 20, 2010 at 8:13 AM
ANGRY
Similar problem on 2005 Ion 2, 29K miles
Jun 9, 2012 at 12:08 PM
SATURNTECH9
  • 30,869 POSTS
Angry if you could please start your own question it would be less confusing and a whole lot easier on me looking for your responses.Start your question with this one is for saturntech9 with complete details on what the problem is and they will leave it for me.Iam the saturn expert on here.
Jun 9, 2012 at 3:36 PM
