2005 Saturn Ion dead battery
40,000 MILES • 4 CYL • FWD • MANUAL
SKIKAT1
How do you measure current flow from the battery if you suspect that you have a current draw after everything is off. I removed the ground cable from the battery and then touched it to the post and got a little spark, and how much current draw is aloud. The battery goes dead after all night on occasion.
Thank you
Sean
Jan 31, 2010 at 5:51 AM
  • 75,988 POSTS
See below battery drain test
https://images.2carpros.com/forum/automotive_pictures/12900_parastic_draw_1_181.jpg
Jan 31, 2010 at 6:00 AM
SKIKAT1
Thank you for the fast reply, it helped. We need a new battery. the amp draw was only 6.75 mili-amp after the system went to sleep. You guys are awesome!! Its close to 6 years old.
Jan 31, 2010 at 7:42 AM
