Car want start unless jump boosted
150,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
TRISH MILLS
Car want start unless boosted then car runs good. But, as soon as the car is turn off it will not start back. Check battery and alternator both good. The car has even cranked with the key turn off while getting a boost. Also, the started stays kick in after the car is running. The car also has cranked with out the battery cable being on the battery. This is the oddest thing that I have every seen. Could this be the ignition.
Apr 5, 2017 at 8:30 AM
TRISH MILLS
Also, I had the starter check at Advance and he told me the starter was fine. But, I have had someone else to tell me even if the starter is good it can cause this problem if something is sticking in the starter itself or something to do with the grounded.
Apr 5, 2017 at 8:47 AM
TRISH MILLS
Please, someone help me with this problem I just bough this car so I could have transportation to get back and forward to a cancer clinic. I have to make multiply trips out of town back and forward to receive cancer surgeries.
Apr 5, 2017 at 8:50 AM
CARADIODOC
  • 34,414 POSTS
Something is wrong here. It is impossible for a starter to work if a battery cable is disconnected. I have a suspicion someone else disconnected the smaller wire at the starter, and something got lost in translation.
The multiple symptoms suggest the starter solenoid is sticking. That has been somewhat of a common problem on '87 and newer GM products. The solenoid housing warps a little, then the metal plunger sticks and may not fully release or it may not fully engage. It's job is to pop a gear out to engage the engine, THEN it turns on a large switch to turn on the starter motor. If it sticks and doesn't release, the starter can continue cranking the engine after the ignition switch is released. If it sticks when you try to start the engine, a jump-start can provide just the little more voltage that is needed to get it to engage. You can do the same thing by tapping on the solenoid while a helper is holding the ignition switch in the "crank" position.
The fix is to replace the starter solenoid, but given the cost and the additional time, the better solution is to just replace the entire starter. They always come with a new solenoid.
Be aware that unlike other forums where anyone can chime in and confuse the issue, here you are in a private conversation. Once you added a second comment, we see your question on the list as having already received a reply, so most of us will skip right over it without reading it. Also, it can take many hours to get a reply. We are only here at various times, so don't panic if it takes a while. We'll stay with you for days or weeks until the problem is solved.
Apr 5, 2017 at 9:40 AM
