it is located about in the middle of the engine compartment, between the cylinder head and transmission. If you look in the middle there, you'll see the large ratiator hose, follow that hose back to the rear of the cylinder head. that hose connects to the thermostat housing. Remove the 2 bolts, and there you will find the thermostat.
Feb 12, 2010 at 7:58 AM
