2004 Saturn Ion Starter fails to function when hot
46,000 MILES • 4 CYL • FWD • MANUAL
KERRY WEISENBORN
Starter will not turn engine over when engine is warm. Starts up after sitting for 20-30 minutes. Does not happen every time. Dash blackes out when trying to start. Clutch is always depressed when trying to start.
Jun 22, 2010 at 4:37 AM
SATURNTECH9
  • 30,869 POSTS
Have your body control module scanned for code's if you have a code B2960 and or B3033 then replace the ignition switch real common problem with the switch's going bad and causing no start's.
Jun 22, 2010 at 4:57 AM
