2004 Saturn Ion some noise and vibration
BAILEY5
Shakes or Wobbles problem
2004 Saturn Ion 4 cyl Two Wheel Drive Automatic
In the last 6 months I have replaced 2 wheel bearings, 2 rotors, 2 struts, steering shaft and then had 4 wheels aligned. Now I can hear a humming noise and when the car reaches 100km there is a vibration in the steering wheel . Any suggestions??
Aug 28, 2010 at 12:05 PM
SATURNTECH9
  • 30,869 POSTS
First thing I would check is wheel balance.Do you only hear the huming noise while driving?If so possibley a wheel bearing or a cupped tire?Run your hands over all your tire tread's feeling for any uneveness.Does it sound like it's coming from the front or back?Which wheel bearings were replaced?
Aug 28, 2010 at 12:21 PM
