2004 Saturn Ion Rt. Frt. Turn Signal
57,000 MILES • 4 CYL • FWD • MANUAL
RICHAMERI
The blue wire going to my Rt.Frt. Turn signal is not getting any power. The same wire also turns on the Rt. Frt. Daytime running Light. I need to find where the opposite end of the wire is from the light connector to find if I am getting power going into the wire. I do not have a wiring diagram. Thank You
Aug 13, 2008 at 7:15 AM
KYLECTOR
  • 6 POSTS
hi. Saturn actually has a recall for the fuse unit. I recommend taking it in for this issue.
Nov 15, 2008 at 7:12 AM
