My ION keeps saying PWR STR SERVICE. It will not start. I checked all fuses and battery. What else could it be?!
Aug 17, 2009 at 3:34 AM
SATURNSERVICEMANAGER
MEMBER
there is a 60 amp mega fuse in the underhood fuse block that is probably blown - this can happen for several reasons including an improperly jump started vehicle. there is a service bulletin regarding this. you should replace the fuse first and see if the vehicle starts. if it is blown and still does not start after replacement, then the engine control module may have been fried.
