2004 Saturn Ion front end noises
130,000 MILES • 4 CYL • FWD • MANUAL
ADAM01PAULA
I was wondering what would kind of problem would make it sound as if the frontend of the car is about to fall out. It is worse in cold weather rather than warm, I have put the car in reverse and driven in a circle with no noise. When going over bumps or turning it makes a lot of popping and clunking noises.
Dec 7, 2009 at 5:16 AM
SATURNTECH9
  • 30,869 POSTS
can u just turn left and right driving in a parking lot and make the noise if so sounds most like ur swaybar bushing need to be replaced and probably the brackets there is a vin cut off for the brackets needing to be replaced for up to 04's saturn has the vin cut off in there parts computer.hope this helps let me know how it goes.
louie
Dec 7, 2009 at 8:24 AM
