2004 Saturn Ion 4 cyl Front Wheel Drive Automatic
My wife's Ion, usually on cold mornings, occasionally will not start. It usally turns over a once or twice before not turing over at all. The battery is fairly new and was load tested (checked fine). Lights do not dim during starting attempt. Usually when I give it 5-10 minutes and retry, it starts up. When it first fires up, after not starting initially, it will die if you do not give it gas. It only does this after it fails to start. The car has 100,000 miles on it. Thanks for your help in advance.
SPONSORED LINKS
Wednesday, April 22nd, 2009 AT 10:24 AM
