2003 Saturn Ion wiring
20,000 MILES • 4 CYL • FWD • AUTOMATIC
PECFRAM1
I am installing a remote start on my Ion. The wiring diagram that came with it is confusing on location of the starter wire and wire for GM passlock. I need to find the wire for passlock so I can run one wire to data side and one wire to key side. I also need the same for starter(key side and starter side) The diagram says there is a blk/white and white under the hood that does both but is confusing me. I would prefer to find them under dash or near ignition.
Mar 2, 2008 at 9:27 AM
MASTERTECHTIM
  • 4,750 POSTS
hang tight ill find iy
Mar 2, 2008 at 11:01 AM
MASTERTECHTIM
  • 4,750 POSTS
my remote starter diagram does not have your vehicle but i grab the starter wire at the ignition switch under dash. ill check in on this post in am and get the info from my alarm guy.
Mar 2, 2008 at 11:08 AM
