2003 Saturn Ion Window
115,500 MILES • 4 CYL • 2WD • AUTOMATIC
LUVBEETLE
What could cause the driver's window to be stuck in the down position?
Sep 3, 2010 at 2:18 AM
SATURNTECH9
  • 30,868 POSTS
A bad switch or most likely a bad window motor.When you push the window switch to the up position if you put your ear on the drivers side door can you hear a clicking noise in the door?Also do you have a multimeter?
Sep 3, 2010 at 4:19 AM
