2003 Saturn Ion starting in cold weather
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
ACARL
Why is the car so hard to start in cold weather. Sometimes it won't start at all. I live in Atlanta Ga!
Jan 4, 2010 at 5:48 AM
SATURNTECH9
  • 30,869 POSTS
have the battery and alternator tested first if that all checks out good also have the body control module scanned for codes u will need a advanced scanner to do that not just a cheap engine code reader if u have a code b2960 and or a b3033 then u need to replace the ignition switch there cheap and easy to change.let me know what u find.
Jan 4, 2010 at 10:08 AM
