2003 Saturn Ion noise while 30 mph+ growling sound loud??
110,970 MILES • 4 CYL • 2WD • AUTOMATIC
RICH HART
I CHANGED THE R FT AXEL,NEW STRUTS+SHOCKS.
SEEMS LIKE FRONT END.
CAN"T GET THE NOISE WHEN RUN ON LIFT?
WHEEL BEARRING SEEM TO BE OK?
TRANS MOUNTS ARE IN LINE?
THE AXEL ON RIGHT WILL WOBBLE A LITTLE IN TRANS IF YOU MOVE IT BY HAND,
HOW TIGHT SHOULD THEY BE?/ M43 TRANS
THANKS RICH
Nov 6, 2008 at 2:06 AM
RACEFAN966
  • 5,029 POSTS
Ok first a hub bearing may sound great on the rack with no pressure on it and make lots of noise on the ground with the weight of the car on it. So I need you do something and listen to your car as you do. I need you to take it for a drive and make left and right hand turns and listen to see if the noise changes. If you turn left does the noise get worse or seem to go away and same on the right. Let me know what you find here and we will go from there ok.
Nov 6, 2008 at 2:42 AM
RICH HART
When turning to the right A little less noise.
Left is same.
p s When replaced right axel tire was cupped alittle?
Nov 6, 2008 at 3:40 AM
RACEFAN966
  • 5,029 POSTS
Well you could put the tire in the back and see if happens to change but I think you will be replacing the right front hub assembly. Sense you can turn right and the noise lessens but when you turn left it stay's then I suspect the right side to be the problem as when you turn right you are lifting the weight off of it.
Nov 7, 2008 at 1:49 AM
RICH HART
I Will replace right hub,
THANKS for your help.
Nov 7, 2008 at 1:50 PM
RACEFAN966
  • 5,029 POSTS
Thanks for you support and let me know how it goes. Have a great weekend.
Nov 8, 2008 at 12:28 AM
RICH HART
IT WAS THE AXEL AND THE GOODYEAR TIRES.
Nov 15, 2008 at 3:43 AM
RACEFAN966
  • 5,029 POSTS
Good then you have it fixed that is great. If there is anything else we can do for you just ask. Thanks again and have a great weekend.
Nov 16, 2008 at 4:29 AM
