2003 Saturn Ion intermittent starting problems
ZEELAND61
  • 2003 SATURN ION
  • 4 CYL
  • FWD
  • MANUAL
  • 50,000 MILES
2003 saturn ion has intermittent starting problens in winter weather. Other sites have mentioned pass-lock problems. Will a remote starter solve this problem if it is the pass-lock system.
Friday, February 5th, 2010 AT 9:34 AM
SATURNTECH9
  • 30,869 POSTS
The most likely cause is ur igniton switch which has ur passlock.U need to get ur body control module scanned for codes if u have a b2960 and or a b3033 then u need to replace ur ignition switch. There easy to replace and there only like 40. So the best and easiest thing to do is just scan for the codes if there then replace the switch. Let me know what u find and how it goes.
Friday, February 5th, 2010 AT 9:58 AM
