[quote:632d0036b6="two rivers"]Running stock rims and tires, 185/70/R14. I think, I can put on 195/60/R15 tires. You think that would help, the tire dealer said it won't help. I think the tires are the problem. Thank You, Richard[/quote:632d0036b6]
If you put the bigger tire's on it will make your speedometer off and not read the correct speed.Now on your tire's not absorbing the bump's in the road it's hard to say on that one since i can't test drive the car to see what's it's doing.I can tell you this though there isn't much in the rear end you haven't replaced that would affect your ride.IT's just the i beam the spring's and the shock's.
Jun 13, 2010 at 3:03 PM
