2002 Saturn Ion DIY Passenger mirror repair
2002 SATURN ION
36,000 MILES • 4 CYL • FWD • AUTOMATIC
BRIGHTGIRL
The passenger mirror on my Saturn ION is hanging by some wires. The mirror still operates with the driver's side control.
Can I fix it myself?
Dec 31, 2009 at 3:04 PM
BLUELIGHTNIN6
  • 16,542 POSTS
should be able to, just takes a few basic mechanic tools. . Use your fingers to grasp the inboard and outboard edges of the mirror. Carefully pull on the mirror face to disengage the attaching tabs from the housing. Remove the upper trim finish panel from the front door. Remove the rearview mirror sound absorber. Disconnect the rearview mirror electrical connector, if equipped. Remove the rearview mirror nuts. Remove the rearview mirror from the door Installation is the reverse of removal.
https://images.2carpros.com/forum/automotive_pictures/261618_0996b43f80202f9f_1.jpg
Dec 31, 2009 at 3:14 PM
