1999 Saturn Ion over heating
BJBLACK1982
Engine Performance problem
1999 Saturn Ion
I recently purchased a used 1999 Saturn Ion and every now and then it overheats. The tempgauge is not showing hot but it will smoke and over flow in the coolant reserve. I had it in to a mechanic and he could not find anything wrong. We keep the reserve filled to the line. Any suggestions?
Jul 28, 2008 at 4:43 AM
  • 75,988 POSTS
Try replacing the thermostat and bleeding the cooling system not it do the following below:
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump
Jul 28, 2008 at 4:59 AM
