1999 Saturn Ion
AL DAVIS
Engine problem
1999 Saturn Ion 4 cyl Front Wheel Drive Manual
i have engine oil in the collant recovery tank; any ideas on cause; should i replace the motor
Dec 18, 2007 at 11:32 AM
  • 31,937 POSTS
Hi there,
Is the engine running rough? miss firing? over heating? oil in the coolant will normally be a head gasket problem, As your sis a manual it will not be a transmission leak via the radiator. Is the oil very low? i would be doing a bit more investigation before installing another engine.
Mark (mhpautos)
Dec 18, 2007 at 9:48 PM
