Transmission swap from CVT to M43
128,950 MILES • 2.2L • 4 CYL • TURBO • AUTOMATIC
TRIGBOA
Just bought this car in April and I have been reading and hearing nothing but bad things about the CVT transmission. Is it possible for me to switch it to a M43 because the CVT just went out on me? I am not a mechanic however. Please get back with me.
May 20, 2018 at 12:01 AM
  • 55,808 POSTS
The transmission swap is viable because it has it's own module. It has been done successfully on other Ion's.
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
May 21, 2018 at 3:38 AM
TRIGBOA
What do you reccomend?
May 21, 2018 at 9:41 AM
TRIGBOA
Wanted to see if you could further assist me with the swapping of a CVT transmission in the car listed above (coupe) to the AF23. Or point me in the right direction. Thanks
May 21, 2018 at 10:40 AM (Merged)
TRIGBOA
Yes, I will get you the VIN number once I am off. I appreciate you sir.
May 22, 2018 at 2:52 AM
  • 55,808 POSTS
I recommend you replace it with the same unit or get another car. Sorry nothing you can do.
