headlight replacement.
2009 SATURN AURA
5,000 MILES • 4 CYL • FWD • AUTOMATIC
MRCOLLEGEMAN
I have a 2009 Saturn Aura and I wish to change the lowbeam lights in it. Is there a easier way that I can get to the H11 bulbs with out having to remove the Front Bumper Fascia?
Apr 12, 2009 at 10:29 PM
SCOTTSRMEK
  • 5 POSTS
We, [Saturn dealer tech's] have tried other way's to make the job easier and faster, but the end result is the fascia must come off. We have found that the facia doesn't have to fully be removed from the car, but does have to be pulled away enough to gain access to the lamp assembly for it to be removed. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Apr 25, 2009 at 11:29 PM
AURA
On the 2008 Saturn Aura XR how do you get access to replace the H11 or 9005 headlight bulbs? There are no instructions in the manual, and short of taking the front end apart, I can't see a way to access them?
Subsequently I've read that you need to remove the front grill and front bumper to gain access to the bulbs!!!With 2008 engineering, can this be true? If so, the people responsible for this design and the approval of this design should be fired and banned from ever working in this industry again. Wake up!!! Light bulbs regularly burn out and require replacement, having to go to the dealer and have a certified mechanic with years of training replace a bulb is as demeaning as it gets!!!! Please tell me I'm wrong and that there is an easier way then disassembling the front end of my car.
Jul 7, 2020 at 3:22 AM (Merged)
BASSTECH
  • 236 POSTS
Unfortunately you do have to partially remove the front bumper cover.
Remove the front bumper cover fasteners from the center and side of the headlamp to be removed, gently pull the fascia forward to allow clearance to remove the headlamp assembly. Remove the three headlamp assy screws, Lift upward and pull the headlamp forward to disconnect the headlamp harness electrical connector. Then twist the bulb out of the socket.
