Changing Engine Oil
100 MILES • 6 CYL • FWD • AUTOMATIC
FTURSO
I want to perform my own oil changes. Please give me the size filter wrench I need for the 3.5 liter engine's oil filter. Also, the location and type of wrench needed to remove the oil drain plug.
Thank you. Frank Turso
Aug 24, 2008 at 5:48 AM
BASSTECH
  • 236 POSTS
The oil drain plug is a 15mm plug, ( need 15mm wrench/socket)) the filter wrench size is a medium.
Here is a guide to walk you through the steps
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
ENGINE OIL TYPE
Look for Two things:
1.GM6094M Your vehicle's engine requires oil meeting GM Standard GM6094M.
2.SAE 5W-30 is best for your vehicle. These numbers on an oil container show its viscosity, or thickness. Do not use other viscosity oils such as SAE 20W-50. Oils meeting these requirements should also have the starburst symbol on the container. This symbol indicates that the oil has been certified by the American Petroleum Institute (API). You should look for this information on the oil container, and use only those oils that are identified as meeting GM Standard GM6094M and have the starburst symbol on the front of the oil container.
NOTICE: Use only engine oil identified as meeting GM Standard GM6094M and showing the American Petroleum Institute Certified For Gasoline Engines starburst symbol. Failure to use the recommended oil can result in engine damage not covered by your warranty.
ENGINE OIL ADDITIVES
Do not add anything to your oil. The recommended oils with the starburst symbol that meet GM Standard GM6094M are all you will need for good performance and engine protection.
Capacities
Engine Oil with Filter .................... 4.8 quarts (4.5 liters)
NOTE: All capacities are approximate. When adding, be sure to fill to the approximate level. Recheck fluid level after filling.
Feb 12, 2010 at 7:10 AM
FTURSO
To perform an oil filter change what size wrench to I need for the 3.5 ltr Saturn engine?
Also, the location of the oil drain plug and the type of wrench needed for the plug.
May 20, 2019 at 7:50 AM (Merged)
BRIAN 1
  • 1,030 POSTS
you will need a 13mm combination wrench or 13mm box end wrench.the oil drain plug is at the bottom of the oil pan. looking up at the bottom it's on the right side. (these engines take 4.5 quarts of oil)post back with any other questions.
