2007 Saturn Aura Key Fob
SEWKITTY
  • 2007 SATURN AURA
  • 6 CYL
  • 52,000 MILES
Key fob does work but only in certain positions outside the car. How can I resync this fob?
Saturday, June 26th, 2010 AT 3:30 PM
SKOOBEJOHN
Most of the Fobs need to be synced by a dealer and some locksmith copanies. Our fob had a couple of loose solders in the fob itsself and had the same issues. Mostly around the battery holder it worked good to lock, unlocking was an issue most of the time there was a small broken tab on one small spot that connected to the motherboard of the Fob gentle soldering and it was done.
Good luck
Saturday, March 3rd, 2012 AT 12:58 AM
SATURNTECH9
  • 30,869 POSTS
If only certain buttons are inop then pop it open remove the board you will most likely see black carbon where the buttons press. Get a tissue clean all that up then clean the buttons where they touch the board. Then reassemble and it should work good.
Thursday, October 18th, 2012 AT 4:25 AM
