2007 Saturn Aura anti freeze leaking
2007 SATURN AURA
RALPH RUBINO
Engine Cooling problem
2007 Saturn Aura 6 cyl
I HAVE A LEAK OF ANTI FREEZE WHICH THE MECHANICS ATSATURN HAVE NOT BEEN ABLE TO FIND, AFTER 4 SERVICE VISITS. I HAVE INDICATED TO THEM THAT IT DOES NOT LEAK ALL THE TIME,
ONLY WHEN THE HEATER OR AIR CONDITIONER
HAS BEEN USED. I HAVE ALSO NOTICED THAT THE CAR HAS BEEN RUNNING HOTER THAN NORMAL.IT IS LEAKING SIZEABLE AMOUNTS OF ANTI FREEZE
NOT DROPS.BECAUSE OF THE PROBLEM I AM
CONCERNED ABOUT USING THE CAR FOR DISTANCE DRIVING.PLEASE HELP
May 25, 2009 at 4:26 AM
BRIAN 1
  • 1,030 POSTS
I find it odd that they could not find a leak,but what did they do to find the leak,did they pressure test the coolant sys?there are also 2 bulletins for this problem,one is for a coolant leak at one or both cylinder heads and one for gaskets leaking at the coolant crossover pipe,both are for the 3.9L and 3.5L engines.I would take it back and have them check a little deeper.
May 25, 2009 at 12:30 PM
