2008 Saturn Astra removal of drivers side mirror housing
DX7KEYS
2008 Saturn Astra 4 cyl
subject line says it all .. How do I remove it ??
Thanks ..
Feb 14, 2010 at 4:30 AM
KHLOW2008
  • 41,812 POSTS
Hi dx7keys, Here are the removal procedures. OUTSIDE REARVIEW MIRROR OPENING COVER REPLACEMENT Removal Procedure
https://images.2carpros.com/forum/automotive_pictures/192750_RearViewMirror08AstraGif04_1.jpg
1. Remove the rearview mirror opening cover. 2. Loosen the 4 top clips (1). 3. Release the 4 lower clips (2). Installation Procedure Install the rearview mirror opening cover. "¢ Install the 4 lower clips. "¢ Install the 4 top clips.
Feb 14, 2010 at 9:47 PM
DX7KEYS
Feb 15, 2010 at 3:52 AM
DX7KEYS
I need to remove the entire mirror housing from the auto ..
Thanks ..
Feb 15, 2010 at 4:08 AM
KHLOW2008
  • 41,812 POSTS
Sorry for the misunderstanding. POWER MIRROR REPLACEMENT Removal Procedure
https://images.2carpros.com/forum/automotive_pictures/192750_RearViewMirror08AstraFig10_1.jpg
1. Remove the upper extension trim panel. 2. Release the 3 clips. 3. Disconnect the wiring harness plug.
https://images.2carpros.com/forum/automotive_pictures/192750_RearViewMirror08AstraFig11_1.jpg
4. Remove the front door outer mirror. a. Disconnect the wiring harness plug. b. Remove the 3 bolts. c. Remove the outer mirror. Installation Procedure 1. Install the front door outer mirror. Tighten: Tighten the 3 bolts to 5 N.m (44 lb in). 2. Connect the wiring harness plug. 3. Install the outer mirror inner paneling. 4. Connect the wiring harness plug. 5. Install the 3 clips. 6. Perform the operational inspection.
Feb 15, 2010 at 4:12 PM
BILBOWAR
Where can I buy just the housing without going to the dealer? My mirror was hit and knocked the housing off and the piece that goes on the bottom is missing. Thank you!
Mar 22, 2010 at 2:05 PM
KHLOW2008
  • 41,812 POSTS
Hi Bilbowar,
The housing is a dealer part so you have no other options.
Mar 23, 2010 at 12:29 AM
