2008 Saturn Astra 2008 Saturn Astra coolant temp wiring
2008 SATURN ASTRA
10,000 MILES • 4 CYL • FWD • AUTOMATIC
GRABBY
  • 8 POSTS
I have a coolant temeture wire with the conector that went mising for the tempeture sensor on the radiator please help thanks
Oct 27, 2009 at 11:18 AM
Hi grabby and TY for the donation The engine coolant temperature sensor is on rear of engine on coolant outlet see no.3
https://images.2carpros.com/forum/automotive_pictures/12900_ect_location_1.jpg
The engine coolant tempearture sensor has 2-wires a blue and red and the other is brown and yellow. 1. blue and red is the ECT sensor 2. brown and yellow is the low reference
https://images.2carpros.com/forum/automotive_pictures/12900_ect_sensor_saturn_1.jpg
Oct 27, 2009 at 11:56 AM
GRABBY
  • 8 POSTS
Hi there is another tempature sensor, the one you guys are showing me is for the engine cooling tempature sensor.
what i need is the wiring harness for the coolant tempature sensor (that coolant temp sensor is located in the radiator on the right side) ((this is how it is)) (basicly i still have the coolant temp sensor in the radiator but the wires and the connector was torn out, well it disapeerd and i do not want my engine to over heat since the fans dont turn on.
please get back to me, thanks
Oct 27, 2009 at 1:42 PM
The only switch left I could located is the engine coolant level switch. I know what you're trying to say I assume its the engine temperature gauge switch that signals the computer to fire up the cooling fan thru a relay on a given temperature.
I want you to identify the wire colors on the cooling fan motor and we'll tap in somewhere temporary to fire up the cooling till you find that wire
Also is this an XE or XR model astra?
Oct 27, 2009 at 3:11 PM
GRABBY
  • 8 POSTS
Hi there are two wires in the fan moter switch 1 is red/yellow number 2 is brown and the model is the astra xr model thanks
Oct 27, 2009 at 8:31 PM
Get a jumper wire long enough to reach from the fan motor connector to the underhood fuse block. Connect one end to the red and yellow wire at the fan motor and the other end to the underhood fuse block relay K1 terminal 87 clip it together with the relay-see below Did the fan come on? key at run position
https://images.2carpros.com/forum/automotive_pictures/12900_k1_1.jpg
Underhood fuse block
https://images.2carpros.com/forum/automotive_pictures/12900_k1_3.jpg
Oct 27, 2009 at 9:24 PM
GRABBY
  • 8 POSTS
Hi it worked the fan turned on but there are two fans on the astra one behind the radiator (on the left)and one in front on the ac condenser (on the right) do i have to do that to the one in front of the ac condenser to, i turned on the one behind the radiator using k2??or is that fan just for the ac??also i am a bit worried having the fan allways on on, there is no tempeture gauge, its just a light that turns on when the engine is over heating but if the sensor is unpluged can the engine still overheat??also is there any way to make that sensor work again beacuse i just cant find it ive looked everywhere??Thanks a bunch
Oct 28, 2009 at 10:13 AM
