2008 Saturn Astra 2008 Satern ASTRA XR Headlight Problems
21,150 MILES • 4 CYL • FWD • AUTOMATIC
JAMESNEEDSHELP
Hi i am having a problem with my satern astra i left the car sitting for 1 month and when i went to start it the battery was dead so i unhooked it to get it charged when i put it and went to start the car the hazards turned on and keep turning on each time i put it in ignition but the car started and drove but then i relized that the headlights were flickering like a strobe light and wuold not stop even when i turned them off please help i think the security need reset or something?? Any help will be greatly appeciated Thank you
Nov 30, 2009 at 9:47 PM
THIS IS MIKE
  • 686 POSTS
Try locking and unlocking the drivers door 3 or 4 times with an original key to reset the alarm. You may have to go to the dealer to have the alarm reset with their scan tool.
Dec 4, 2009 at 7:32 AM
JAMESNEEDSHELP
Hi it does not work .do you know if there is any way to disconect the alarm to see if it is causing the problems before i take it to the dealers?? Thanks much appeciated
Dec 4, 2009 at 8:42 AM
THIS IS MIKE
  • 686 POSTS
Try disconnecting the battery for an hour and let the system try to reset properly. If it continues to malfunction, it sounds like the alarm module has failed.
Dec 16, 2009 at 5:17 AM
