1993 Saturn Astra Engine trouble
1993 SATURN ASTRA
150,000 MILES • 4 CYL • FWD • MANUAL
MWD55
while driving, the car just died and now it wont start
Aug 27, 2009 at 9:59 AM
Do below to determine if its fuel or spark problem
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module,
Aug 27, 2009 at 10:56 AM
