p1155 code
12,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
DRIFTERDRUMMER
  • 15 POSTS
Injector malfunction still there after repairing wires and changing the injector on cylinder two. Threw me a p1155 code. I found out I left unplugged wire to TED. What should I do now? I understand there is a procedure to reset it so it can relearn itself . Anyone familiar with this procedure? Please explain.
Sep 12, 2016 at 4:47 AM
HMAC300
  • 48,601 POSTS
it takes a scanner to erase codes an auto parts store may do it.
Sep 12, 2016 at 5:01 AM
DRIFTERDRUMMER
  • 15 POSTS
took it to two auto parts stores neither one could erase it. said it had two other permanent codes stored also. i just need to know how to reset the ETS? i read it somewhere. Also saturntech9, which injector harness will work on my car?
Sep 12, 2016 at 7:11 AM
HMAC300
  • 48,601 POSTS
this may be a PCM problem which should be investigated by a mechanic. if you still have a wire disconnected reconnect it if you took it off. if you did not then it may go to something else.
Sep 12, 2016 at 8:20 AM
DRIFTERDRUMMER
  • 15 POSTS
The wire was disconnected by me. I forgot to reconnect it. I reconnected it. How do I get the com tested or ECM ? Injector wire looks like rodent chewed it. I replaced his just just that one. Should I try to find a 3.5 injector harness? What other harness will fit it?
Sep 12, 2016 at 8:54 AM
HMAC300
  • 48,601 POSTS
if you repaired it by soldering and using shrink wrap then it is okay. a professional should check the ECM because if it is bad he has to program it to your car anyhow.
Sep 12, 2016 at 9:37 AM
