Safety/emissions
200,000 MILES
TEIGHLOR LOVE
  • 10 POSTS
Will my car fail safety and emissions with a bad wheel bearing, alignment and heat that doesn't work?
Front right end has a lot of grinding noises ans a bit of shaking while driving 30 mph or higher. I am assuming that is either alignment or a bad wheel bearing. Brakes/rotors maybe? The faster i go the louder it is.
Apr 4, 2019 at 2:18 AM
Good afternoon,
What state do you reside?
I would say yes, to the hub bearing as that will fail and could cause a failure of the suspension.
As far as emission, if the check engine light is not on while running and the monitors are good, then it will pass that portion.
Apr 4, 2019 at 5:26 AM
