Safe mode/Limp mode
150,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
SANTOSNIEBLAS
Engine RPMs are high ,once I shift it into gear safe mode comes on.
Aug 31, 2021 at 6:42 PM
SQM
  • 6,383 POSTS
Typically with the safe mode (limp mode), you will have the check engine light come on. Which many times can indicate why the vehicle is in safe mode.
Is your engine light illuminated?
Unless you can determine why the safe mode is activated it will be difficult to get the vehicle off of the safe mode.
https://www.2carpros.com/articles/reduced-power-limp-mode
One of the leading cause for limp mode is a dirty throttle actuator. Which many times will trigger the check engine light.
Please let me know.
Sep 1, 2021 at 1:23 AM
SANTOSNIEBLAS
Have cleared codes, cleaned electronic throttle body and replaced, input, output speed sensors, cleaned EGR ,hoses, PCV valve, spark plugs. found oil in my third plug. O ring and gasket is next, but had no code on that!! RPMs still high. showing a code about gas pedal sensor. Going to also get that.. recap: car goes in safe mode doesn't engage D or 1st reverse at times.
Sep 1, 2021 at 6:33 AM
SANTOSNIEBLAS
Thanks again on a quick response.
Sep 1, 2021 at 7:02 AM
SQM
  • 6,383 POSTS
Are you getting any transmission codes? Like a module of solenoid code?
Sep 1, 2021 at 12:31 PM
