I just got back my block from the machine shop. I forgot to ask what was removed, but from what is written on the block it appears .040 was removed. I have purchased a truck Norris cam, 7.4 chromoly pushrods, .560 beehive springs, 243 heads milled .0015, std bore flat top pistons, .050 head gaskets, and everything else is std/ stock. The question is, have I exceeded the safe mill limit for block? And is this set up going to work still or what do I need to do to have good quench and compression? I was aiming for 10.1 originally. Thank you!
Apr 22, 2023 at 1:15 AM
