2002 Saab 9-5 Brake Whistle
SAAB
GREGSTOLHAND
Saab 9-5
2002
59000
4 cylinder turbo
Currently when driving when I release the brake a whistling noise (sounds like air is coing from behind the pedal) occurs as I let off brake. If I am accelerating it does not occur.
Please advise?
Nov 9, 2007 at 9:02 AM
MERLIN2021
  • 17,250 POSTS
Does it provide power while braking? this is the check valve or a shaky diaphram in the booster...check valve is at the end of the vacuum hose that attaches to the booster, take it out and try sucking thru it both ways, air should travel in one direction only! If it's the diaphram, drive tell the brakes get hard...EXPENSIVE!
Nov 9, 2007 at 9:13 AM
Suggested Repair
Test the brake booster check valve at the vacuum hose: air should flow only one way. If the booster diaphragm is failing, the brakes may become hard and booster replacement is expensive.
Conversation Summary
A 2002 Saab 9-5 owner reports a whistling sound like air behind the brake pedal when releasing the brake, but not while accelerating. The expert attributes it to a faulty booster check valve or a failing booster diaphragm and advises a one-way airflow test of the check valve.
