1993 Saab 9000 clutch
160,000 MILES • 4 CYL • FWD • MANUAL
ASLOON
Last night I stopped at ta gas station and when I came back out I couldn't put the car into first gear. Depressing the clutch doesnt seem to do anything and I can shift through gears as if I had depressed the clutch. Whats going wrong with it and what needs to be fixed?
Dec 19, 2007 at 12:14 PM
  • 31,937 POSTS
Hi there,
What is happening when you depress the clutch, is it feeling normal, is the pressure resistance? Will the gear stick move at all, can you move it through the neutral gate. These questions will aide in a diagnosis.
Mark (mhpautos)
Dec 19, 2007 at 2:08 PM
